no rear brakes
Old Apr 19, 2011 | 10:59 PM
k.jward09's Avatar
no rear brakes
i have an 86 camaro v6 2.8l and the rear brakes dont work. the fronts work and the e-brake. what should i do next?
will no brakes in the rear fail a texas state inspection?
Old Apr 19, 2011 | 11:08 PM
Re: no rear brakes
No brakes in the rear will fail anywhere.......
Check the master cylinder for low fluid in the section for the rear brakes. Check the rear brake lines and the calipers (or wheel cylinders) for leaks. Blead the brakes.
You should have the "BRAKE" light lkit up on your dash, indicating that there is an imbalance in the front and rear portions of the braking system. Is it on?
Old Apr 20, 2011 | 12:31 AM
k.jward09's Avatar
Re: no rear brakes
i just change the right rear wheel cylinder and still no brakes. i know its getting brake fluid. none of the lines r pinched.
Old May 18, 2011 | 03:45 AM
L.dookie's Avatar
Re: no rear brakes
how do you know you're getting fluid? just because fluid drips out when you change a cylinder doesn't mean that you're "getting fluid"
Old May 18, 2011 | 02:19 PM
Re: no rear brakes
After changing the wheel cylinder, did you fully bleed the system? Did you fill the master cylinder first? Was the wheel cylinder leaking?
CGM2010CAMARO
Apr 7, 2015 07:44 PM
Jlo
Apr 3, 2015 10:32 AM
Jazsun
Dec 29, 2014 12:14 PM
trefidy
Jul 26, 2002 03:40 PM
