Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel Rail Question for 500+ hp LT1......
Old Apr 10, 2011 | 03:11 PM
new2chevy's Avatar
Hey guys...question for anyone who knows..
If I am running a 383 LT1 with around 500 to 550 hp and a 150 shot of nitrous, should I do the parallel fuel rail mod, or will the stock (series) fuel rail setup with a good fuel pressure regulator be sufficient?
Thanks to anyone who knows and replies.
Old Apr 10, 2011 | 03:19 PM
RobbyRob's Avatar
Re: Fuel Rail Question for 500+ hp LT1......
The stock fuel rails are right there @ 550hp. anything more would call for the upgrade or modding the stock rails..
Old Apr 10, 2011 | 05:03 PM
Are you runing a wet nitrous system, or a dry system? Only a dry system puts the fuel for the nitrous through the rails. Are your HP numbers rear wheel, or flywheel?
Old Apr 13, 2011 | 09:07 AM
new2chevy's Avatar
I would run a wet system. It'd be 550 flywheel horsepower or less, without nitrous. I hear that there are 2000 hp engines using series fuel rails and that this series/parallel debate is moot.
Old Apr 13, 2011 | 11:13 PM
Nothing wrong with running in series if the rails are large enough to minimize the pressure drop, and thereby minimize the difference in fuel pressure between the first injector in the path and the last injector. But the question is, are the stock LT1 rails large enough to minimize the pressure drop at 800 or 1,000HP?
I don't know of an LT1 making 2,000HP on stock series rails, but I do know what has been done for specific 800HP and 1,125HP LT1 power adder applications.
Old Apr 14, 2011 | 01:00 PM
rskrause's Avatar
Moderator
Stock will work fine.
Rich
HectorM52
Jul 30, 2017 11:46 AM
LT14LIFE
Feb 9, 2015 09:35 PM
rcajun86
Jan 30, 2015 01:56 PM
birdblack
Dec 30, 2014 06:59 PM
Jul 4, 2005 05:00 PM
