how to make ride smoother with summit springs
Old Feb 21, 2011 | 08:08 PM
vangill's Avatar
my ride on my 94 z28 is very rough, id like it to be a bit smoother as im about to be putting sfc's on this weekend and i heard those will stiffen it up a bit.
im unaware as what brand shocks are on it, the fronts are black and the rear red.... but im assuming they arent correct anyways which shocks would soften it up a bit
or should i be looking more into tires? i have 17's front and 18's rears-the rears what feels more stiff
Old Feb 21, 2011 | 10:16 PM
Re: how to make ride smoother with summit springs
What air pressure are you running in the tires? What are the full tire size designations?
Old Feb 21, 2011 | 10:44 PM
MikeGyver's Avatar
18" wheels? so like 35 series tires? that's just how they ride lol
Old Feb 22, 2011 | 08:54 AM
vangill's Avatar
They are 245 45 17 front and 275 40 18 rear. I'll get pressures today
Old Feb 22, 2011 | 10:06 PM
40-aspect ratio on the 18's shouldn't cause unreasonable harshness. But some tires can be worse than others. The 40's are probably 1" larger diameter than stock, if your car left the factory with the Z-rated tire option.
Old Feb 24, 2011 | 06:05 PM
vangill's Avatar
So what would be good shocks to pair with these springs? Would a stock replacement like Gabriel ultras or Monroe reflex be any good?
DirtyDaveW
Dec 1, 2016 05:37 PM
cmdeshon
Dec 12, 2014 10:51 PM
Dec 1, 2014 08:08 AM
Elcojoe
Nov 17, 2014 10:27 PM
