BeCool Radiator fitment problem
Old Jul 16, 2010 | 05:44 PM
LazyLemming's Avatar
Hi folks,
I ordered the Becool radiator 60028. It's in perfectly, except the Oil Cooler Bypass Line (#16 http://shbox.com/1/95-97_hoses.jpg) does not fit. The radiator has a threaded hole where the hose should connect. Anyone put in a BeCool and run into this problem? I'm not seeing any kind of adapter available.
Old Jul 16, 2010 | 06:26 PM
RamAir95TA's Avatar
Plug the inlet on the radiator and plug the outlet on the water pump. Problem solved.
Old Jul 16, 2010 | 07:33 PM
So... They're not needed?
Old Jul 16, 2010 | 07:36 PM
RamAir95TA's Avatar
Nope. You can block both off no problem.
Old Jul 16, 2010 | 07:42 PM
Not arguing... just trying to understand this stuff better, but if the oil bypass isn't necessary what is it there for in the first place?
Old Jul 16, 2010 | 09:14 PM
Kevin Blown 95 TA's Avatar
For when the cars which have oil coolers need it. They didn't want to make two different ones.
Old Jul 17, 2010 | 12:11 AM
RamAir95TA's Avatar
Yep. It keeps the water pump universal for all year f-bodies.
Old Jul 17, 2010 | 06:19 AM
Wonder why the factory put a hose in it, rather than just plugging the holes????
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
