Engine going out?
Old Jul 13, 2010 | 01:27 AM
bayboii925's Avatar
Engine going out?
So i was getting on the freeway on July 4 after picking up my girlfriend and half way home my car died on the freeway.i was going about 65 in 5th gear so i down shifted and gave it a bit more gas and when i did that i felt something pop or break. i felt that through my steering wheel. And know when you turn the car on theres a klnoc and sounds like a whine also. i took it to the shop today and they really didnt get underneath the hood but they think its the lower end and that the motor going out. Someone please fill me in and tell me its not the motor and something minor.
Old Jul 13, 2010 | 01:41 AM
RamAir95TA's Avatar
A good indication of a motor's health is it's oil pressure. How's your oil pressure when this happened?
Old Jul 13, 2010 | 05:11 AM
When you start the engine, the AIR pump should start. That could explain the whine. Hard to believe a shop would attempt to diagnose a "klnoc" without popping the hood. Makes no sense at all.
Old Jul 13, 2010 | 07:55 AM
razor02097's Avatar
with bottom end problems the motor will usually knock or have a thump sound with squeeking like a rusty door hinge when it idles. Very noticeable and usually unmistakable.
Is it leaking any fluid?
Will it start and idle?
How much oil pressure do you have?
How does it run? Does it have any power?
Is your service engine soon light on?
Old Jul 13, 2010 | 07:57 AM
craby's Avatar
i take it the car runs, so its knocking all the time now? agree with above what the oil pressure? is it jumping up and down? if you can, lets hear a recording.
Old Jul 16, 2010 | 10:48 AM
bayboii925's Avatar
I believe the day of my oil pressure did start to move up and down. when i would gas it the oil pressure would go down but when i let off the gas slowly it went up. but it usually never went down if anything it would go up. I do have a minor oil leak now. The car still drives and everything but it doesnt have close to as much power as it should. Also my 02 sensor that connected to my intake broke. it sounds like the whole car is broken
Old Jul 16, 2010 | 12:29 PM
RamAir95TA's Avatar
There are no "02 sensors" connected to your intake. The only sensors on the intake duct are the IAT and the MAF. Both of them need to be connected.
You say the oil pressure went down then up, how far down did it go? The more info we have here the better.
Old Jul 16, 2010 | 12:57 PM
henryz28's Avatar
A bad lower end should sound something like this http://www.youtube.com/watch?v=WA4G_LDEflo
Old Jul 16, 2010 | 07:43 PM
gillta95's Avatar
Any codes? Wheres the oil leak from? back, right side?
Old Jul 17, 2010 | 10:07 AM
Chaos1187's Avatar
Out of curiousity, what type and grade engine oil did you use on yours??
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
centric
Aug 15, 2002 09:04 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
