P0420 Code that keeps coming back
Old Sep 23, 2008 | 11:39 AM
02OrangeDropTop's Avatar
Help! I'm losing my cool over this. My 2002 3800 Y87 Camaro with 107K miles on it continues to throw a "P0420 - Catalyst System Efficiency Below Threshold (Bank 1)" code no matter what I've tried to fix it.
Here is what I've done so far:
1. Replaced catalytic converter
2. Replaced all 3 O2 sensors (2 at manifold and 1 post catalytic converter)
3. Replaced Engine Coolant Temperature sensor. (thought that false hot reading was causing incorrect air/fuel mix)
4. Sea Foam treatment to clean injector nozzles.
I'm about out of ideas. Has anyone else seen this issue? Any other recommendations?
Old Sep 23, 2008 | 12:06 PM
JakeRobb's Avatar
Super Moderator
Have you cleared the code after each of those repairs? It doesn't go away on its own, even if the problem is fixed.
Mine (an LS1) is currently throwing the same code -- I am having the converter replaced under warranty. Hopefully I don't end up having the same problem...
Old Sep 23, 2008 | 01:06 PM
Yes, I have cleared the code after fix. After a day or so it comes back.
Old Sep 23, 2008 | 06:26 PM
ACE1252's Avatar
This is from my 1996 factory manual, but should apply to your V6 as well. Right click and view image to view at full size.
Old Sep 25, 2008 | 12:52 PM
TrocN98's Avatar
mine has been throwing the same code since last year when i put and aftermarket magnaflow exhaust with an aftermarket hiflo magnaflow cat on it. i dont know what to do to make it go away either...ive heard that an 02 simulator is needed. dunno where to get one, which one to get, and where to put it on the car...help please
Old Sep 27, 2008 | 01:00 PM
ACE1252's Avatar
I think your problem has got to be the cat. Look above.....the manual states to make sure that the cat is OEM spec. Your highflow cat is not working to the PCM's satisfaction. I know for certain that a muffler will not hurt anything. I ran one on my 96 3.8 without issue(dynomax superturbo from RKsport).
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
Rich_z28
Aug 29, 2002 10:44 PM
MJ_Z28
Aug 8, 2002 09:07 PM
ford
Aug 3, 2002 02:39 PM
