Leak fro Above Oil Filter
Old Aug 4, 2008 | 02:31 PM
musict96camaro's Avatar
Leaking oil from above oil filter. I have oil prssure guage and Pro Charger plumbed into the 1/4" NPT hole jsut above the filter. I just took all that apart and put together with teflon tape...... definetately not leaking from there.
Took inspection mirror to the back side of the head / valve cover and intake manifold, and appears to be dry from the top.
Is there a block plug in the area that would cause oil to leak from above the oil filter (other than the one mentioned below)??
Not ******* my car, but I seem to chase oil leaks constantlly on this LT1 motor.
Thansk for your input!!
Old Aug 4, 2008 | 05:14 PM
Are you sure the oil filter adapter hasn't come loose?
Old Aug 4, 2008 | 05:24 PM
83tpi_3rd-gen(sri)'s Avatar
^^^thats where i would check.
Old Aug 4, 2008 | 05:39 PM
Stoopalini's Avatar
In my experience, teflon tape does not work that well on oil. I tried it once on the oil pressure sending unit, and it always leaked. I removed the tape, and used ARP thread sealer; hasn't leaked a drop since.
Thomas.
HectorM52
Jul 30, 2017 11:46 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
97 RedSS
Jun 10, 2003 07:58 PM
