has there been a computer problem with 97's-2000's??
Old Jun 2, 2008 | 05:17 PM
DanM458's Avatar
I'm having a misfire problem during acceleration and my SES light is on. I took it to two places to get the diagnosis and they both say MAF sensor and vacuum leaks. I cannot find a vacuum leak anywhere and replaced my MAF sensor last week. I talked to another guy who was one of the auto parts stores and he said sounds like it could be the computer and that GM had a problem with the computers on the camaros and firebirds between 97-2000, is there any truth to this???
Old Jun 4, 2008 | 12:24 PM
94-TAGT's Avatar
I don't think so
Exactly which codes are you setting?
Old Jun 5, 2008 | 03:01 PM
DanM458's Avatar
Im gettin MAF sensor, vacuum leaks, and multiple cylinder misfires....the car runs great tho, and the MAF sensor is only about 2 weeks old and im not finding any vacuum leaks and the car idles fine too
Old Jun 9, 2008 | 01:48 PM
94-TAGT's Avatar
The multiple missfire and vac. leak codes are often set by a broken EGR... check the egr, check the place where the egr connects to the upper intake for a leak (spray TB cleaner on it and listen to see if your idle changes). Also if its not the EGR you could spray around your throttle body to intake manifold connection and see if that gasket is leaking.
Magenta_Hearts
Mar 25, 2015 10:24 AM
IgorT.455/406
Mar 12, 2015 03:39 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Absolute Z28
Jul 19, 2002 02:21 PM
