looking to relocate alternator....and keep PS
Old Jan 10, 2008 | 01:37 PM
reamo04's Avatar
well, my car is a street car...so I need to keep my power steering
Unfortunately, I must also move my alternator for my build
I do not have A/C, so I was looking at either
A) trying to move the alternator where the AC normally is
B) finding a way to move the alternator to the driver side
Does anybody have any ideas?
Ive heard of a kit to move the alternator to the driver side, but I cannot find it for the life of me
Old Jan 10, 2008 | 04:37 PM
"Search".... there is a thread with photos of an alternator moved to the A/C position, with an idler bolted where the alternator would normally go. The amount of "wrap" on the alternator drive is a bit skimpy, but the guy claims it works.
Old Jan 10, 2008 | 04:54 PM
reamo04's Avatar
yeah, I saw that. I was wondering if there was an actual place that would do it, because I don't think that will work for what I need if the idler pulley is where the alternator normally is for height
Old Jan 10, 2008 | 05:03 PM
Zigroid's Avatar
these are all the pages I have bookmarked over the past regarding alternator relocation. they may or may not have relevance to what you want to do, but it's a start.
https://www.camaroz28.com/forums/sho...d.php?t=448192
https://www.camaroz28.com/forums/sho...d.php?t=417671
http://www.ls1tech.com/forums/showthread.php?t=497408
https://www.camaroz28.com/forums/sho...d.php?t=518959
https://www.camaroz28.com/forums/sho...d.php?t=512043
https://www.camaroz28.com/forums/sho...d.php?t=525395
http://www.ls1tech.com/forums/showthread.php?t=835359
Old Jan 10, 2008 | 05:19 PM
FASTFATBOY's Avatar
Why do you NEED to move it? I have tall valvecovers and shaft rockers with the alt in stock location.....have the sheetmetal valvecovers notched.
Look up Turbo_6 on here, he had Thunder do his with no goofy looking pullies mounted up top.(I dont remember any anyway)
David
Old Jan 10, 2008 | 05:36 PM
reamo04's Avatar
because, I am going to have a turbo pipe right where the alternator is normally...
Old Jan 10, 2008 | 11:26 PM
lt1rx798's Avatar
can you mount it backwards? i don't know if the f-body has room, but im running mine the other way.
http://i64.photobucket.com/albums/h1...8/IMG_0578.jpg
Old Jan 11, 2008 | 07:17 AM
GaJoe's Avatar
how in the world do you keep your belt on?
Old Jan 11, 2008 | 11:58 AM
reamo04's Avatar
IDK if that would even give me enough room. I need room for a 2.5" pipe to run through there, and then some clearance on both sides so stuff isnt rubbin
Old Jan 11, 2008 | 12:18 PM
FASTFATBOY's Avatar
I HAVE seen them mounted on the drivers side down low before, that would be what you really need.
David
Old Jan 11, 2008 | 12:30 PM
reamo04's Avatar
David
yeah, ive searched, but couldnt find out how to. Any idea?
Old Jan 11, 2008 | 12:52 PM
thesoundandthefury's Avatar
A couple of things:
1. I posted about this topic, (for the umpteenth time) back in Nov, and you PM'd me asking about the bracket I made mention of and I explained how you would go about setting it up, with a pic included.
2. The same explanation I gave you in that PM can be found in a couple of the links that "Zigroid" posted. The pic that can be found in those links is the same as the one I sent you in the PM.
Based on those two pieces of information alone, the fact that you're still here asking about this again suggests that you're beyond help. If the issue of how to mount your accessories is this hard for you to figure out, then I'm sorry, but you're in way over your head wrt a turbo setup.
Old Jan 11, 2008 | 03:21 PM
reamo04's Avatar
Originally Posted by thesoundandthefury
Argumentive/Insult content deleted.
heres where i ask about the driver side setup
Today 12:30 PM
reamo04
Today 12:18 PM
FASTFATBOY I HAVE seen them mounted on the drivers side down low before, that would be what you really need.
David
like I said, read the thread. I know what was origional asked, and, I also said that I cannot change it to where the alternator is where the AC was, and the pulley is up top. No need to be a dick about it.
I know I could use the zoops kit and madman kit, and that may be what I ultimately end up doing. but I was looking for other solutions as well.
Old Jan 11, 2008 | 05:45 PM
FASTFATBOY's Avatar
[deleted]
NOW THEN, I will do a search over on LS1 tech, I have in fact seen it done. SOMEWHERE.
I will get back with ya.
David(The guy who cant build his car)
Last edited by Injuneer; Jan 12, 2008 at 02:38 PM. Reason: No need to call anyone names
Old Jan 11, 2008 | 06:04 PM
FASTFATBOY's Avatar
I found this
http://ls1tech.com/forums/showthread...ion+alternator
But Speed SPecialty has since either been bought out or changed hands, I cant find it on the site.
COntact PEPE in that post
David
