relocating alternator
Old Jun 8, 2007 | 09:28 AM
96LT1TX's Avatar
Do any of you guys know if there is an aftermarket bracket that moves the alternator under the passenger side header? I have seen one example where someone moved their alternator down under the plug wires on the passenger side, and this would save me a TON of time and problems when re-adjusting RR's... also if I want to install a supercharger in the near future . Also, if anyone knows of any other way to relocate this I am definitly interested in any different place NOT above a valve cover. Some nice crome valvecovers would look nice.
any advice appreciated, thanks
Old Jun 8, 2007 | 11:05 AM
There are a couple of alternator relo brackets for the LT1 (Madman, SJM) but they are used when there is nothing being driven except the alternator. I've seen a couple attempts to develop marketable systems for relocation of the alternator while still running PS and A/C...... might want to try a "search" - people have posted some photos, I believe.
Old Jun 8, 2007 | 12:00 PM
thesoundandthefury's Avatar
Some inspiration. This guy made his own brackets out of blocks of billet aluminum, and converted to a CS130 alternator and a Type II "TC" P/S pump. (For clockwise rotation):
Like Injuneer pointed out, there are alternator only brackets available. It's only when you try to keep more than the alternator that things start getting complicated. Our stock "CB" P/S pumps are internally vaned to rotate counter-clockwise, so that must be taken into consideration when changing accessory positions and belt routing.
Old Jun 8, 2007 | 02:50 PM
96LT1TX's Avatar
interesting, ya the only thing that will be used that is belt driven is the power steering pump. I dont have anything in my AC system still installed except the actual compressor because I liked using stock size belt. If I could find some way to mount the power steering elsewhere that would be nice... that pic is a good idea. anyone know where to find this type of power steering pump?
Old Jun 9, 2007 | 10:32 AM
dtrsam's Avatar
I just did a little trimming on the stock bracket, made a couple simple brackets one on the front and 1 on the back. Even reused the stock Alt. with no mods to it at all. It's a tight fit but there is plenty of clearance for me.
Old Jun 9, 2007 | 11:40 AM
Projectz28's Avatar
Moderator
As much as I like this one and the idea, I can tell you there is no way there is enough belt to pulley contact to make this set up reliable. Under load the alternator will want to stop turning and the belt just has no where near enough contact to keep it going.
It will probably work for light loads and may even be usefull for a while but its not a good belt configuration...
You should try to get that tensioner to push up and run the belt over it then to the alternator. Might take some custom bracket or even some other tensioner.
Old Jun 9, 2007 | 11:52 AM
Projectz28's Avatar
Moderator
something like this would be much better...
Old Jun 9, 2007 | 11:57 AM
dtrsam's Avatar
Your idea is much better, this is just what i came up with in a hurry (and for free). So far it has worked out fine, has been running for over a year with no problems, with a regular diet of 6500 rpm.
Old Jun 9, 2007 | 08:34 PM
96LT1TX's Avatar
moving the tensioner there would make it near impossible to change plug wires is the main problem I see. The first picture I like best, what kind of a crank pulley is that? I am interested in that crank pulley and the power steering pump if anyone knows where to get something like that.
Old Jun 10, 2007 | 03:18 AM
At one time my plans were to do something very similar to what you're wanting to do so I did quite a bit of research on it. I came across a low mount driver's side power steering bracket that fits LT1's from a company called "Zoops." I ended up buying it but in the time since then my plans have changed somewhat so I no longer have any use for it. Here's a pic:
(I took the liberty of giving it some attention with the buffing machine.) This bracket is a pretty slick design because the "claw" that holds the pump actually slides fore and aft to make it easier to adjust for pulley alignment. The stainless link bar is both a support and acts as a belt tensioner. (Can be adjusted.) When installed it looks something like this:
One end of the stainless link bar uses a water pump bolt to hold it in place.
Compared to what I paid for my cast iron TC pump, this is a smoking deal because it has the better aluminum pump and comes with a v-belt billet pulley already installed:
http://cgi.ebay.com/ebaymotors/Unist...QQcmdZViewItem
And a billet v-belt crank pulley:
http://cgi.ebay.com/ebaymotors/ALUMI...ayphotohosting
Here's the Madman bracket that mounts your alternator low on the passenger's side that you can just run off the stock serpentine pullies:
http://www.thunderracing.com/catalog...id=166&sid=604
This is as close to a "bolt on" operation as you're going to get for something like this. Since you'll be using a separate pulley on the front of the balancer for the power steering, you might possibly have to use some spacers behind the bracket to get it to sit far enough out to line the pulleys up, but that would be the extent of it. If you like the power steering bracket, I could probably cut you a deal on mine since I won't be needing it anymore. Never used, was only taken out of the package for inspection/pics. PM me if interested.
Old May 29, 2008 | 11:21 AM
Michiganspeed's Avatar
Try one of these
https://www.camaroz28.com/forums/sho...58#post5397758
Old May 29, 2008 | 03:08 PM
cASe SenSiTive's Avatar
Exposed Member
Originally Posted by Michiganspeed
I had one on my SS and it worked great.
Old May 29, 2008 | 05:13 PM
Wicked1's Avatar
hmm...interesting
Old May 29, 2008 | 06:58 PM
Thanks for the kind words Tom. Did you ever sell that beast?
Devinfoote87
Feb 12, 2016 03:21 PM
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
