oil pressure off the charts
ok, so today i installed my lt4 springs, 1.6 rr's, 7.200" cromoly pushrods...
anyway, i di my valves with each cylinder at TDC then i installed my rr's and set the preload to 3/4 turn past zero...
i am using a 10wX30 motor oil...
at idle my pressure is 40 but when i get into the throttle it pegs out way past 80...
before the swap in would max out at 65-70...
what do you think is the reason for high pressure...
what would you recommend...
i did not change the oil however it is fresh (only about 300 miles)
could it have anything to do with the moly grease that i used...
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
