oil pressure off the charts
Old Mar 24, 2007 | 08:22 PM
ZL1modified's Avatar
ok, so today i installed my lt4 springs, 1.6 rr's, 7.200" cromoly pushrods...
anyway, i di my valves with each cylinder at TDC then i installed my rr's and set the preload to 3/4 turn past zero...
i am using a 10wX30 motor oil...
at idle my pressure is 40 but when i get into the throttle it pegs out way past 80...
before the swap in would max out at 65-70...
what do you think is the reason for high pressure...
Old Mar 24, 2007 | 08:45 PM
The work you did should not have had any effect on oil pressure. Do any messing around by the oil pressure sensor?
Old Mar 24, 2007 | 09:09 PM
no, in fact it is a brand new sending unit... i notice the car pulls alot harder but i am not comfortable with that oil pressure...
what would you recommend...
Old Mar 24, 2007 | 09:13 PM
seawolf06's Avatar
It's possible something was dropped into the heads and clogged something up causing higher pressure. You changed the oil before you started her back up?
Old Mar 24, 2007 | 09:21 PM
i am pretty certain that nothing fell in...
i did not change the oil however it is fresh (only about 300 miles)
could it have anything to do with the moly grease that i used...
Old Mar 24, 2007 | 10:03 PM
Hook up a mechanical gauge to verify the reading.
Old Mar 24, 2007 | 10:05 PM
mdacton's Avatar
for sure.....I would try that first before you jump to conclusions
Old Mar 24, 2007 | 10:20 PM
i don't want to sound stupid but i have no choice...
how is this done?
Old Mar 24, 2007 | 10:39 PM
mdacton's Avatar
gauge will have adapters to tap in to the pressure circuit...there should be a pressure port over the filter(area)
or you could just remove the sender and put it in there....either way
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
