intake ??
Old Jan 26, 2007 | 10:18 AM
hot936spd's Avatar
intake ??
will porting and polishing the stock intake do anything, will i see any power gains, seal needs replacing anyways. this is on stock LT1. also would it be worth getting a new ignition box would that help me out any, reason being i know someone one selling one a decent price, thanks
Old Jan 26, 2007 | 10:21 AM
2000GTP's Avatar
On a stock LT1, a ported&polished intake manifold and a ignition box are not good starter mods and will really be of no benefit until you add a cam and ported heads into the mix. Start with a cold air intake and some exhaust work if you want to gain some extra power.
Old Jan 26, 2007 | 02:24 PM
Z28SORR's Avatar
Port and Polish is kind of an old term. I don't think anyone polishes intake ports any more, though they still polished combustion chambers. What your really asking about is port matching, where the outlet ports on the intake manifold and the inlet ports on the heads are machined to match so there are no restrictions to the air flow. At the same time, usually the valve pockets and combustion chambers are also done. And things like over size valves and springs are installed, a "racing" valve jobs is done, etc. in prep for a "bigger" cam.
Like 2000GTP said, this by itself will not make a noticable difference.
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
MadMav
Jun 15, 2015 09:51 PM
jwade88
Jun 14, 2015 09:38 PM
Countryboychevy
Jun 13, 2015 02:49 PM
maybe2fast
Mar 26, 2015 08:34 AM
