Out of ideas. PCM??
Old Oct 31, 2006 | 06:11 AM
Red-LT1's Avatar
Out of ideas. PCM??
My car has been giving me a lot of trouble lately. I think it might be the PCM. The last time it was working OK the speedomoter and the charging gauge were kind of whacked out.
Then the car simply wouldn't run. It threw code 18. I cleared it and eventually it started and ran for long while. Now it had codes 18, 16, and 42. The optispark on it is under 10,000 miles, and last time I replaced both the optical sensor and the cap and rotor. I find it hard to believe I have a real Lo-res failure.
Now, when i turn the key on, engine off, the dashboard is dead. There is still power to my radio and locks and windows, but the dashboard is a gonner.
I'm really at a loss. I just want some opinions before I blow I don't even know how much on a PCM.
Thanks in advance.
Old Oct 31, 2006 | 07:04 AM
Could be your ignition switch or connection to it or even a fusible link.
Old Oct 31, 2006 | 07:17 AM
What do you mean by the dash is "dead" - all the lights, instruments and gauges, including all the ones that have nothing to do with the PCM (fuel level, oil pressure, coolant temp, system voltage)?
Doesn't sound like the PCM. Sounds like a system voltage problem, faulty grounds, etc.
Old Oct 31, 2006 | 11:21 AM
Red-LT1's Avatar
The gauges do nothing. Unless I try to start it. And the SES light isn't on like it should be.
Old Oct 31, 2006 | 12:03 PM
Red-LT1's Avatar
Well this is odd. If i hold the key slightly past aux it will go into auxililary mode but then my radio cuts out. This one has me stumped. I guess I'm gonna have to take it somewhere.
Old Oct 31, 2006 | 12:24 PM
They'll probably tell you it's the ignition switch.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
