Idle problems
Old 06-11-2019, 08:30 PM
Armando_h_94's Avatar
Idle problems
So i have a 1994 camaro, fairly stock LT1. I had issues to what i thought were misfires. So i replaced the plugs and wires. And everything seemed fine. A few days later the idle was bad. Talked to a few friends and they dont even understand. My idle in drive seems to slowly drop as the car warms up. I have checked all possible vacuum hoses and none seem to be broken or cracked. Is there anything else it could be?
Armando_h_94 is offline
Old 06-11-2019, 08:59 PM
Re: Idle problems
Target idle speed is set by the PCM based on coolant temperature, higher idle when cool, dropping as it warms up. Fully warmed up, what is the idle RPM (in gear and in neutral)? Target fully warmed up is 550 RPM in drive and 650 RPM in neutral. Stable, or varying up and down?
Is it just idle RPM that you consider “bad”, or is there an additional problem, like stumbling or roughness?
Injuneer is online now
Old 06-15-2019, 08:48 AM
Germansheperd's Avatar
Re: Idle problems
Coolant temp sender?
Germansheperd is offline
Old 06-15-2019, 10:51 AM
Re: Idle problems
Typical..... signed off immediately after his first post, hasn't signed back in in 4 days. Couldn't have been too important.
95LT4Z28
11-25-2016 08:54 PM
KyleBlue85Iroc-Z
03-29-2005 12:28 AM
carguyshu
07-06-2004 10:34 AM
Fastbird93
08-17-2003 01:07 PM
Blk94Z28LT1
06-25-2003 11:22 AM
Quick Reply: Idle problems
