Zaino question
Zaino question
I've been told that if you mix Z2/Z5 with ZFX in the 2 ounce bottles that come with the ZFX you have to clean the bottle so it's completely clean. If the bottle doesn't come totally clean (I guess this means no residue left on the inside of the botle) then it shouldn't be used again. I'm just curious, why? I don't see why it would matter. How could this left over residue affect any thing???
Assuming you want to use the bottle again it would be best to get the Zaino out before it set up and got hard. If you don't want to use the bottle again you can always toss it.
I put a few drops of Dawn in the bottle with some water, shake it real good, dump that out and let the bottle air dry.
It's not a big deal as long as you wash out the bottle well. I use pure alcohol and hot water and it works great. Shake the alcohol up and it removes the residue very quickly, then rinse it out thoroughly. Takes maybe 2 minutes... Let it dry and you're good for another use!
Thanks for the replies. I have been cleaning the bottles thoroughly with isopropyl alcohol and dish soap. I noticed after the bottles dry there is a little bit of a residue left on the inside, nothing like dried up crusty wax and it comes off easily if I just rub it. I guess I don't really need to buy new bottles then. Thanks.
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
