T-Rex In-Line Fuel Pump
Old Dec 12, 2003 | 05:01 PM
OBE1 95Z28's Avatar
Just installed an in-tank Walbro so I removed my T-Rex pump that was supplied with my Vortech kit. $110 shipped.
Tod
Old Jan 29, 2004 | 09:25 PM
OBE1 95Z28's Avatar
TTT
Old Feb 3, 2004 | 11:55 PM
OBE1 95Z28's Avatar
TTT
Old Feb 18, 2004 | 09:01 PM
OBE1 95Z28's Avatar
ttt
Old Feb 18, 2004 | 10:03 PM
simple's Avatar
can you tell me how that pump gets installed and where in the lines?
and any other info you can give me about using one for an NA car?
Steve
Old Feb 19, 2004 | 09:23 AM
OBE1 95Z28's Avatar
The pump gets installed in the feed line that comes from the gas tank leading to the fuel rail. It physically mounts to the underside of the floor pan, up above the axle (basically right behind the lower part of the rear seat). I can make a copy of the mounting/wiring instructions that came with the Vortech kit for you. This pump supplements the fuel thats delivered by the stock in tank pump. If your NA car is experiencing any dips in fuel pressure due to high fuel demands (i.e. high rpm), this pump will add to your fuel supply. The best solution is a bigger in tank pump (that's what I ended up doing later) but you've got the hassle of pulling the fuel tank to replace the pump.
Old Feb 19, 2004 | 09:49 AM
simple's Avatar
thanks for the honest reply!
looks like i'll pass on it good luck with the sale!
Steve
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
