Pacific Alaska, California, Hawaii, Oregon and Washington
Swap is finished, car won't start - any ideas?
Old Mar 17, 2003 | 01:57 AM
Draco's Avatar
Allright guys....
we tried to fire her up and no dice. Here are the symptoms:
1. Car cranks very laboriously.
2. some backfiring into the intake.
3. when we unplug the coil wire at the coil, the car cranks much smoother - does this suggest opti not installed properly?
4. the ground wire from the coil to the driver side fender gets very hot
Here are some other facts:
1. we are getting spark - we pulled a plug and checked
2. we are getting fuel, since the injectors are ticking - is the ticking enough to verify that we are getting fuel? any other ways to check this?
3. the roller rockers seem to be ok.... so i doubt it's a compression problem. the motor is VERY hard to turn over by hand, even harder then my stock 350 with 10.5:1 compression (this motor is 8.5:1).
There is one known problem right now - the ground wire that attaches to the block right near the starter motor is not connected.... coud this cause the problem? I doubt it since if the engine is cranking, the starter is obviously working. unless this wire is interfering with the spark......
I am going to have to work on the car this week - any volunteers want to come over to Shaun's in the evening and check this out? Whoever figures out the problem gets a cash prize (or I can make an additional donation to the food bank in lieu).
Old Mar 17, 2003 | 02:07 AM
sleeperZragtop's Avatar
..are you at home or still at Shawn's?...do you work Monday afternoon? I'm free...
Old Mar 17, 2003 | 02:08 AM
Draco's Avatar
I'm home, got my dad to pick me up
Old Mar 17, 2003 | 02:10 AM
edit
Old Mar 17, 2003 | 02:13 AM
Draco's Avatar
I can get the time off work. That is very kind of you.... we can give it a shot if Shaun approves. Meanwhile I will scour the boards and come up with alternatives.
Old Mar 17, 2003 | 02:18 AM
....just call my cell, 604-785-5835...my car is well on it's way...it's like putting a model together, slow, perfection and beauty
Old Mar 17, 2003 | 02:19 AM
Draco's Avatar
You bastage .
I wouldn't wish what I am going through on my worst enemy, hehe. I am glad things are coming together well for ya!
Old Mar 17, 2003 | 02:57 AM
sideways_Into_3rd's Avatar
said it on the phone .. said it on MSN .. saying it one last time
fix ur plug wires and fire it up
if its not ur plug wires .. then stevie probably had one too many *potent* canadian beer when he was puttin in ur opti
Old Mar 17, 2003 | 11:14 AM
97TA-WS6-Con's Avatar
Yeah I think checking the wires is a good idea. not sure about the "compression" issue. I guess if the plug wires were wrong that would help explain that problem.
The car does seem to labour when trying to turn over. We missed a BIG ground wire to the motor and we also need to work on the small ground wire at the starter area. However, even after fixing the big one the car still laboured.
I will be home this afternoon although I have a hockey game at some time tonight.
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 12, 2014 10:51 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
smokin5s
Jul 24, 2003 10:47 PM
