Pacific Alaska, California, Hawaii, Oregon and Washington
Street Twin Question?
Old Nov 15, 2003 | 04:02 AM
StreamlineZ28's Avatar
clutch is in and drives good,and grabs like hell. but when i start the car the clutch kind of whines until the motor turns over. almost sounds like a blower starting. like the disc's rub for a second and then stop. just wondering if it will always do this or just when new or if it is not supposed to at all.
Old Nov 15, 2003 | 08:40 AM
xxsaint69x's Avatar
mine did that too...You will need to shim your starter.
Marcin
Old Nov 15, 2003 | 09:37 AM
Jason Dove's Avatar
GM sells the shims btw, you're supposed to cut them in half when you put them in. They came on the corvettes.
Old Nov 15, 2003 | 01:03 PM
thanks, now i just need to adjust the peddle a bit again and it will all be done. didnt take as long as i thought either. started at
2pm on thurs day worked till 8 then from about 11:00 till 8 on friday . always takes longer put it backin. its a b!tch to line up the tranny and putting in a new pilot bushing was a pain in the a$$. didnt think it was to bad for having only taken the tranny out once before. it took me 5 1/2 hours last time to get the tranny out and this time it only took me 3 1/2
Old Nov 15, 2003 | 02:49 PM
sideways_Into_3rd's Avatar
mine never whined at startup ... i guess the newer ones might be different
my tranny dropped out in 30 minutes but then again .. i had no heads on the motor
mark these words: "The street twin will find the next weakest link in ur drivetrain really fast" ..
so be prepared to break something very soon specially that barbie sized 10 bolt of urs
Old Nov 16, 2003 | 10:22 PM
12 bolt will hopefully come in may when i take my vacation payout.
Ringmaster72
Feb 25, 2015 03:15 PM
jmzlt1
Mar 13, 2003 07:26 AM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
RichJ
Aug 11, 2002 10:14 PM
SABLT194
Aug 3, 2002 09:33 AM
