Pacific Alaska, California, Hawaii, Oregon and Washington
Stepped headers
Old Jul 17, 2003 | 09:27 PM
Camaro ChriSS's Avatar
Stepped headers
Has anyone here found it worthwhile to go with Stepped Headers? 1 3/4 to 1 7/8, or otherwise? Thanks.
Old Jul 17, 2003 | 09:31 PM
OneFlyn95z28's Avatar
I hear they make more HP. My next set will be 1 7/8 to 2in
Old Jul 17, 2003 | 09:54 PM
Tw!tchb!tch's Avatar
It is supposed to be benificial . . . err Im not sure if it would be noticable without a pretty maxed out combo eg heads big cam and true duals . Check out edelbrocks new stepped long tube ls1 header . They also come with volocity merge collectors very similar to qtp's for a fraction of the cost . You WILL need to ship them out for coating though as I think there only available in black . which ones were you thinking of ?? Kooks ??
Old Jul 18, 2003 | 12:17 AM
Yes, I was wondering how much air flow you'd need to be doing to make it beneficial. I would assume that a blower or H/C would like the stepped design.
OneFlyn, you're definitely thinking big.. but it sounds like your car wants it!
I do like the looks, design and sound of Kooks. The Edelbrocks look like a little bit of work to play with, lookingt at coating, the slip on collector, etc... But, I not confident that the extra moola (for the Kooks) is really worth it in the end. I think I may grab a set of those Pacesetters and dyno them. See how they do.
Old Jul 18, 2003 | 12:34 AM
mr_muff's Avatar
yes you should ill chip in 20 bucks for the dyno. i wanna see how much the do.
Old Jul 18, 2003 | 02:38 AM
KTamez's Avatar
1 7/8 - 2" Step, 3.5" Collectors
http://outlawrace.com/Misc/Dsc00153.jpg
http://outlawrace.com/Misc/Dsc00156.jpg
Sort of a tricky deal, for some combinations they work, others they don't....
For the most part a Standard 1 2/3" or even 1 7/8" header will work just fine. The Most powerful LT1 car ever built used regular ole 1 3/4" Hookers, although this isn't to say he wouldn't have picked up with a better/larger header.
Old Jul 18, 2003 | 10:35 AM
Thanks Kurtis. That helps.
Blair, I'll hit you for the 20... maybe.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
TitoPR221
May 26, 2015 12:20 AM
detroit1994z28
May 14, 2015 12:09 AM
birdblack
Dec 30, 2014 06:59 PM
