Pacific Alaska, California, Hawaii, Oregon and Washington
LS1 Header boys inside !!
Old May 22, 2004 | 11:10 AM
Tw!tchb!tch's Avatar
Whos running restrictor plates in the air lines ?? Im woried about burning the check valves up . . . .
Restrictor plates :
Old May 22, 2004 | 05:55 PM
Drumhawk's Avatar
No headers yet but they are near the top of my list of mods.
Old May 22, 2004 | 06:30 PM
Camaro ChriSS's Avatar
I am. I think its mandatory based on what others have found. I've had one check valve DTC where it was sticking open. LTs really work the check values hard.
Old May 23, 2004 | 10:43 AM
Hey Chris,
Did you just make yours or buy em ??
Old May 23, 2004 | 02:09 PM
I just made them.
Old May 23, 2004 | 02:17 PM
sideways_Into_3rd's Avatar
Interesting point .. though LT1 guys never ever ran into this problem .. i dont know why
maybe its because most of us just ditch that crap .. as should you guys .. their useless anyway
Old May 23, 2004 | 06:11 PM
Im concidering it . .. . I have been told it wont burn up my cats if i remove it . . . . not sure if it would throw a code though . .
Found this.
Old May 23, 2004 | 06:45 PM
It will throw a code to remove the AIR system for sure, but I think thats the worst it'll do. If I recall, they're just there to help preheat the cats faster so that the cats start working sooner, just after start up, when emissions are worse.
I am thinking of removing the stuff as I just had a P1415 code come back the other day (check valve not opening/closing properly), even with the restrictors. But I may double check to make sure I don't have a bad gasket on the AIR fitting.
Thats the thing with a restrictor plate - in between the fittings you need a gasket, then the plate, then another gasket, which makes more room for errors/problems.
Old May 23, 2004 | 07:08 PM
thats good info . . . . I think ill start planing for its removal and order up some block off plates. . . . . . I hate looking at the ses light though .
As a bonus I hear its worth in the neighbourhood of 6# off your nose.
Old May 23, 2004 | 08:57 PM
KA0S's Avatar
This is the first Ive heard about this. Got any links Dave?
Old May 23, 2004 | 11:30 PM
Why yes I do . . .
http://riptide63.homestead.com/restrictor.html
Old May 25, 2004 | 03:44 AM
11secproject's Avatar
I took off my EGR and AIR system w/o ever throwing a code. I did use LS1-edit later just to make sure it wouldn't ever cause one for sure. Now with the LT's I just installed today, I have no hook-ups!!!
Jason
Old May 25, 2004 | 10:11 AM
I'm not TOO sure how Aircare will handle the readings from our OBD-II ports if the emissions equipment is removed. Likely, since they only see DTCs it will be fine and go unnoticed, but don't quote me on that. That's the only grey point.
Old May 25, 2004 | 10:42 AM
I did some diging around on ls1tech and was told its only some brands of headers that eat check valves . . . . I have no idea if this is true but I couldnt find a case relating to kooks so I think Im going to just run them as is and if they die .. . . . in which case Ill do the !air mod then.
How big was your air tube from the header itself chris ?? I cant stick my pinkie finger in the tube . . . . looks pretty small
maybe2fast
Apr 23, 2015 08:55 AM
grabbem88
Mar 18, 2015 01:25 PM
LT1runner
33
Jul 24, 2002 01:19 PM
