Guys with 17" or 18" X 11"....
hey man
my 17x11 wheels with 315 rubber fit in the back without ANY banging or modification .. it doesnt rub or anything at all
i stuck my hand up the wheel well and there seems to be .5" of clearance at the tightest point
its an LT1 thing
but seriously, u just bought the wrong offset .. my wheels have a mad offset spacer built into them ...
though my FRONT wheels seem to be rubbing the wells
... gotta look into that soon
its an LT1 thing
...no I think it's becasue it's a vert, correct me if I'm wrong but it seems though everything that fit's an f-body dosen't fit a vert...everything I bought was for "vert only"....you have to remember, we need the xtra bracing from the factory...the wheels are stock C5 offsets...I don't really know for sure why they are having a hard time going in....I'll manage...
Mike, what are the exact sizes of your wheels? My C5 rims came from a 99 C5 and fit without a problem. No scraping, no rubbing, nothing. I had them mounted in 275 series rubber on all four corners. I have heard the same thing you have about F-Body Verts...it seems like a totally new set of rules applies to them sometimes
BTW - How was JD's birthday???
.BTW - How was JD's birthday???
Hey Ali....
...how's it going? I hope well....JD's birthday was good, missed you guys..he had nothing but good things to say about you..anyway the wheels are 17x8.5 up front and 18x10.5 in the rear..I'm gonna head out to Surrey tonight and mess around with it...it should be fine, just alot of mending...I need that car on the road to feel the TC and FLP's...I'm already dreading how loud it will be will the loudmouth, ORP and the headers...I may have to rid of the Loudmouth and go for true duel setup..we'll see...take care bro;
Mike
Mike
IMO your 10.5's out back with the 275's will look and feel amazing. My car felt like it was on train tracks, even before the BMR suspension went it. As for your other mods, including that new cam, your car will definitely make some power this season. Let me know when you're working this weekend - we should all go out after you, JD, George, and the boys are done work.
Good luck with the car...can't wait for a ride in the droptop
In my experience there is no differnence between the converts and the coupes re: wheel sizes. Seems to be a bit of an urban legend. AFS to this DAY say the wheels with the GS offset will not fit converts. I even sent them a picture LOL
I have the ZR1 wheels from AFS. I had to do some banging in the rear wheel well but nothing i did not expect or do difficult.
Convertibles have no different wheel wells than regular F-bodies. Plenty of convertible owners run 17x11 rear tires with the same issues as the base-level cars.
Here's a nice tip however: buy a Pontiac.
The ~1" wider 1/4 panels make it possible, nay, PREFERABLE to run the standard GM ZR1 offset (36mm I believe). Chevy 1/4 panels are a bit narrower and cause lip-tire rubbing problems with 315 tires. The solution of course is to run a smaller offset, ala Grand Sport dimentions of 50mm.
Doing this however makes for more "massaging" of the wheel well area.
When you take the hammer to your wheel wells, make sure you have some zinc-primer, or some POR-15 on hand to prevent future rust. Undercoating wouldn't hurt either.
Check out Brent's page for info on the 17x11" issue, it mentions most of what you need, except for us Pontiac guys which have that extra clearance to run the true GM ZR1 runs (which are lighter than any aftermarket designs and come FORGED for more strength
http://www.bfranker.badz28.com/fbody/links.htm#11inch
http://u2.netgate.net/~jshapiro/z28/315s/
I may have a GM set lined up for my own use, but I gotta look into the cost to chrome them (in the future), and what I can afford right now.
Doing this however makes for more "massaging" of the wheel well area.When you take the hammer to your wheel wells, make sure you have some zinc-primer, or some POR-15 on hand to prevent future rust. Undercoating wouldn't hurt either.
)http://www.bfranker.badz28.com/fbody/links.htm#11inch
One more thing. While the GM ZR1's came in silver, and the GM Grand Sport rims came in black (which GM no longer makes/sells apparently), there are ZR1-style rims made by AAA Rims, and by AFS which are available in powdercoat colors, chrome, and even this:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2400727609
deffiently get you noticed... in a good way or not I can't really tell though. May be able to pull it off in a silver or black car I guess.
..thanks guys, I'm gonna pick up some 1/4" spacers, remove the bump stops and hopefully I on't have to bang the wells. I need to run this car soon or I'm gonna **** my pants...
Sergio
Jan 27, 2016 04:27 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
, a bit overboard for the street, but for SEMA....yes
