Pacific Alaska, California, Hawaii, Oregon and Washington
additional fuel gauge
Old Jun 30, 2003 | 01:58 AM
zman0069's Avatar
ok, well since there is already a gauge pod in my car, sitting there with a boost gauge in it (havent taken it out since i bought the car), i wanna know if i can switch this with a secondary fuel gauge, and what the wiring will entail. (my current fuel gauge is annoying, takes 5 bucks to fill up the first 3 quarters then another 35 for the rest, and it goes WAY past the full line.
Old Jun 30, 2003 | 03:15 AM
I AM CANADIAN's Avatar
if you put a aftermaket gauge in will it not read the same as your stock gauge? The gauge gets its info from the sending unit in the tank so if you wirer the 2 together it will be getting the same signal. I would check your sending unit and/or the float in you tank to make sure it is not sticking or having some other problem
Old Jun 30, 2003 | 04:28 AM
zman0069's Avatar
well i know its reading full when its full, and empty when its empty, i was actually hoping that there was one that will actually read out a number as to how much i have left.
Old Jun 30, 2003 | 01:31 PM
Black Robe's Avatar
The potentiometer (variable resistor) in the tank unit provides a matched signal for the gauge unit. Infinite resistance will read max gauge travel toward full. If you 'add' another gauge, the results will be worse than you have now. Of course you could put an 'A/B' switch in too so you can choose which signal to believe!
Garcia5
Jul 7, 2022 06:51 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
IDOXLR8
Aug 6, 2002 12:30 PM
