additional fuel gauge
ok, well since there is already a gauge pod in my car, sitting there with a boost gauge in it (havent taken it out since i bought the car), i wanna know if i can switch this with a secondary fuel gauge, and what the wiring will entail. (my current fuel gauge is annoying, takes 5 bucks to fill up the first 3 quarters then another 35 for the rest, and it goes WAY past the full line.
if you put a aftermaket gauge in will it not read the same as your stock gauge? The gauge gets its info from the sending unit in the tank so if you wirer the 2 together it will be getting the same signal. I would check your sending unit and/or the float in you tank to make sure it is not sticking or having some other problem
Garcia5
Jul 7, 2022 06:51 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
