New England Area For members in Connecticut, Maine, Massachusetts, New Hampshire, Rhode Island, and Vermont.
U think i will pass MA emissions?
Old Nov 17, 2006 | 07:30 AM
  #16
Joe Crehan's Avatar
Originally Posted by jgeorger
It's a balancing act between HC and NOx and I'm not sure you can do it without cats. If you lock the car in open loop and lean it out, HC will drop. However that causes combustion temps to rise and thus NOx wil rise as well.
All cams have an overlap period between the intake and the exhaust valves while both are open. Therefore no matter how perfect your combustion is, you will always been getting some HC's right from the intake out the exhaust.
I don't disagree with what you are saying. I'm just saying that he's a certified emits expert and he thinks it's doable. Personally I'd still go with the legal set up and just add elec cut outs.
The slick route is with the SLP system. They come with removable cats. All you do is install the supplied straight pipe after the sniff test. Really slick is adding the cut outs to the straight pipe.
Old Nov 17, 2006 | 01:55 PM
  #17
CamaroRacing12's Avatar
my plan is to put my cutouts on right after the collectors on my longtubes with clamps.....so then when the sniff test comes around im gonna replace them with cats.....sounds doable right?
David Dempsey
Mar 12, 2016 12:42 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
sherwinZ28
11
Aug 15, 2015 05:38 PM
Cam's maro
Aug 11, 2015 07:45 AM
