Zex Dry Users Please Help!
Old May 5, 2007 | 04:03 PM
pyro719's Avatar
i need to know what jet sizes you guys are running for 125 shot, I have a stock fuel system with no booster pump. Thanks in advance.
Old May 6, 2007 | 05:15 PM
pyro719's Avatar
I know some of you run the zex dry kit come on now.
Old May 6, 2007 | 06:00 PM
CamaroSS30thAnn's Avatar
i cant remeber exactly what the numbers were but i picked this up using the SEARCH fuction
75 HP will need #40 nitrous jet and #82 fuel jet.
100 HP will need #46 nitrous jet and #78 fuel jet.
125 HP will need #52 nitrous jet and #73 fuel jet.
Old May 6, 2007 | 07:38 PM
pyro719's Avatar
I searched for 4 hours bro those numbers just dont seem right? Im running a 52 nitrous jet with a 34 fuel jet and it just dosnt seem to be rich? wouldnt a 72 fuel jet lean it out big time?
Old May 6, 2007 | 07:54 PM
no i believe those numbers are right.
IIRC the jets that i used were 50 somthing and 70 somthing , lol i wish i had my instructions in front of me
but yea that seems about right to me
ill do a little more search and c what i can come up with
Old May 7, 2007 | 08:50 AM
pyro719's Avatar
That would be awesome! Also do you know what fuel pressure I should be looking for when the nitrous is flowing? I am still on the stock fuel system.
Old May 7, 2007 | 03:21 PM
your gonna need a 255lph fuel pump
not sure about the fuel pressure
Old May 7, 2007 | 07:21 PM
pyro719's Avatar
I have been spraying it all weekend with the #52 nitrous jet and #34 fuel jet with no fuel issues wouldnt the #72 fuel jet put less strain on the pump?
Old May 7, 2007 | 08:08 PM
http://www.zex.com/Base/Instructions/ZEX130.pdf
thats the install instructions, jet sizes are on the last page
for the dry system all of these are correct
to run the 125 shot (or even the 75) you are going to NEED either the booster pump or a 255lph
the stock fuel pump cant flow well at higher fuel pressures, ull end up running way lean. You probably already are u just dont know it. Running lean = KABOOM.
My reccomendation to you , is if u want to use nitrous do it right!
second if you are running teh 125 and u have not done so already u will also need 1 step colder plugs gapped at .35 (NGK TR6s are great)
thats about all i have to offer, good luck with whatever u do
Old May 7, 2007 | 08:35 PM
pyro719's Avatar
I will order a walbro 255lph from ape and go with the correct jets. Thanks for all your help.
Old May 8, 2007 | 03:07 PM
good luck man , hope u enjoy
or and ur sig says u have 2.73s
id def look into 3.42s- 3.73s
night and day diff ull pick up a bunch of time at the track as long as u hook
Old May 8, 2007 | 08:04 PM
pyro719's Avatar
Yea 373's will be my next mod along with drag radials, headers and an ory. I should be happy after that.
2QUIK6
Sep 17, 2016 02:31 PM
tnmotown
Aug 10, 2015 11:52 PM
NewsBot
Jul 29, 2015 08:10 PM
Boss002
Jul 24, 2015 10:47 AM
mrwz28
Jul 8, 2015 09:11 PM
