Window Switch setpoints
Old Mar 21, 2006 | 10:45 PM
357LT1's Avatar
What are you guys setting your WS for you nitrous setup? I currently have it to start at 3k and off at 6.2K. Can I start it sooner? Can I turn it off later and do I want to? Thanks!
Ramiro
Old Mar 21, 2006 | 10:49 PM
Bow94z's Avatar
Re: Window Switch setpoints
i'd say leave it at 3k, then depending on what you shift at and your rev limiter is set at you adjust accordingly
Old Mar 21, 2006 | 11:10 PM
Firehawk_Dude's Avatar
And by "adjust accordingly" I would assume a few hundred RPM before shift point???
Old Mar 21, 2006 | 11:13 PM
357LT1's Avatar
OK 3k sounds good! So if I shift at 6.8K, 6.6K is a good cutoff point?
Old Mar 21, 2006 | 11:17 PM
Bow94z's Avatar
yea sorry i failed to mention that, figure he would just think that
Old Mar 21, 2006 | 11:18 PM
I figured... just making sure everything is crystal clear :-)
357LT1 - yes, 6.5k or 6.6k
Old Mar 22, 2006 | 06:55 AM
BlownF1's Avatar
I run mine at 2800, with a 2500 stall...
Old Mar 22, 2006 | 03:54 PM
357LT1's Avatar
How high do you take it up to on your stroker?
Old Mar 22, 2006 | 06:57 PM
BlownF1's Avatar
I currently have it set to shut off at 5800, but that's a bit early I think. I've yet to get everything dialed in and set where I want it, but I'll plan to have it shut-off around 6200, and shift at 6400-6600 eventually.
Old Mar 22, 2006 | 07:19 PM
Where does your 383 stop making power at with that setup?
Old Mar 23, 2006 | 06:19 PM
BlownF1's Avatar
I couldn't really tell you at this point. The first time on the dyno, the trans went. The second time on the dyno, it wasn't building more than 3psi of boost due some sort of restriction in the intercooler system. Still haven't sorted that one out.
Old Mar 23, 2006 | 09:24 PM
Got ya. Well let us know when you get that beast up and running on a dyno
Old Mar 24, 2006 | 01:30 AM
TMoNeE98's Avatar
2500-5700
Old Mar 24, 2006 | 10:45 PM
TMoNeE98
2500-5700
What's that?
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
z28cam1993
Sep 9, 2015 04:08 AM
