Window Switch setpoints
What are you guys setting your WS for you nitrous setup? I currently have it to start at 3k and off at 6.2K. Can I start it sooner? Can I turn it off later and do I want to? Thanks!
Ramiro
Ramiro
Re: Window Switch setpoints
Originally Posted by bow94z
i'd say leave it at 3k, then depending on what you shift at and your rev limiter is set at you adjust accordingly
Originally Posted by Firehawk_Dude
And by "adjust accordingly" I would assume a few hundred RPM before shift point???
Originally Posted by 357LT1
How high do you take it up to on your stroker?
Originally Posted by BlownF1
I currently have it set to shut off at 5800, but that's a bit early I think. I've yet to get everything dialed in and set where I want it, but I'll plan to have it shut-off around 6200, and shift at 6400-6600 eventually.
Where does your 383 stop making power at with that setup?
I couldn't really tell you at this point. The first time on the dyno, the trans went. The second time on the dyno, it wasn't building more than 3psi of boost due some sort of restriction in the intercooler system. Still haven't sorted that one out.
jackpawt883
Sep 10, 2015 08:53 PM
z28cam1993
Sep 9, 2015 04:08 AM
