What plugs and wires to run???
Old Jun 4, 2003 | 10:07 PM
Jcb890's Avatar
hey guys,
right now im stock and comtemplating going w/ a NX wet kit sometime down the line. basically im askin what the best plug wires and plugs to run are for a nitrous set-up and will these wires and plugs be OK if i eventually don't wind up doing nitrous? oh, also where shud i look to get a good price on the stuff - Summitt?
thanx,
jake
Old Jun 5, 2003 | 04:21 AM
RUFFIDLNZ's Avatar
Most people either run the Autolite 104's, NGK TR-6's, or an AC Delco plug (dont know the number but you can find it on here if you do a search). As far the wires any aftermarket wire would be good. A lot of people have Taylor's, MSD's, Accel......... As far as the best price I really have no answer for this but Summit does have some good prices and fast shipping (at least for me they have)
Old Jun 5, 2003 | 10:37 AM
Jcb890's Avatar
yeah, i remembered a lot of ppl using the NGK but forgot what one exactly it was and i totally 4got about the autolite plugs. as for the wires, thats pretty much what i expected.
thanx,
jake
Old Jun 5, 2003 | 10:44 AM
Jcb890's Avatar
Oh yeah, and i should go w/ like a MSD 6AL or a new MSD or similar ignition right? i think almost all ppl on the board do this when they run nitrous. now i could just buy and install the ignition when i decide to buy the nitrous and put it on the car or wud it b easier to do it at the same time as the plugs and wires? sorry if my questions r dumb, but i dont know much about nitrous and im trying to learn more so i can run some on my car and not blow up. and thanx to those who post and help me out.
jake
Old Jun 5, 2003 | 04:28 PM
rpm4lalo's Avatar
I have MSD 8.5 superconducter wires with Autolite 104's.
Old Jun 5, 2003 | 04:42 PM
RacinLT1's Avatar
you can use the ignition box now or later. I would suggest going with the Digital 6 or Mallory Hyfire 6(i believe this has a built in window switch).
Plugs any non platinum plug 1-2 heat ranges colder then stock.Wires some guys use stock wires,but whatever you decide,make sure they are in good condiditon.
Im currently running Taylor 409's wires and NGK TR6's.
Old Jun 5, 2003 | 10:43 PM
RUFFIDLNZ's Avatar
Definetly get you an ignition before you go spraying. If you hit the rev limiter on your stock ignition it will cut the fuel which is not a good idea With an ignition box like the 6al or the Digital 6 which is what I have it will cut the spark which really still isnt great but at least its better than cutting the fuel. Also the Digital 6 has an onboard rev limiter that you can set for just when the nitrous switch is on which is very beneficial.
Old Jun 8, 2003 | 11:19 AM
TMDZ28's Avatar
which one of these wires should i get that will fit my car, and good enough for 50-75 shot of wet kit....thanks
http://www.ls1speed.com/catagory.cfm...%20Electronics
PCLZ28
Dec 24, 2015 05:19 PM
Jazsun
Dec 29, 2014 12:14 PM
IRABuss
Sep 7, 2011 09:08 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
