What can I use for a sealer?
Old Nov 2, 2004 | 08:28 AM
buzz12586's Avatar
I bought a NX pressure gauge for my Nitrous Works kit and when I hooked it up there was nitrous leaking through where the gauge connects and on the silver screw opposite the gauge. What can I use to put on the threads (cuz both sides screw in) to keep it from leaking? I want something that won't be harmful for it but I am not sure what to use.
Old Nov 2, 2004 | 09:29 AM
LPEdave's Avatar
Re: What can I use for a sealer?
On a pipe or NPT fitting, teflon tape works well. Just keep it off the very last thread so it won't fall off into the line.
Dave
Old Nov 2, 2004 | 04:03 PM
buzz12586's Avatar
My friend said not to use tape cuz it would get in the line. Is this true? Is there anything else I can use?
Old Nov 2, 2004 | 05:14 PM
Fast94bird's Avatar
Use red loctite. A little goes a long way. Never use teflon tape on any fitting unless it is a last resort.
Old Nov 2, 2004 | 07:53 PM
buzz12586's Avatar
Alright I'll try some red loctite. Thanks for the advice.
Old Nov 2, 2004 | 08:56 PM
gb95zconv's Avatar
I just use the teflon paste...works well....not a pain in the ars if you need to take things back apart like loctite would be.
Old Nov 2, 2004 | 08:58 PM
jay_lt4's Avatar
red locktite is what comes with the kits, it works very good if you clean the threads with a wire brush
Old Nov 3, 2004 | 12:08 AM
buzz12586's Avatar
Yea I don't plan on taking it apart and putting it back together much so I think the locktite would be fine.
Jeff1904
Jun 5, 2016 05:00 PM
ACE1252
Oct 18, 2004 11:18 PM
ibanez6rg
Jan 16, 2004 09:50 AM
ryaskovic
Sep 10, 2003 10:34 PM
