Spraying through shifts
Old Dec 3, 2003 | 07:49 PM
z2894convertible's Avatar
I have a built 700R4. I was curious as to what it can hurt on the tranny if I sprayed through the shifts.
Old Dec 4, 2003 | 01:27 AM
cef97ws6's Avatar
Well depending on how much torque you are making at the shift points will have a lot to do with it. But the weak points in the tranny are going to be the planetary or sprag I would think. I used to run a 700r4 behind a 396bb in a chevelle with a 150shot years ago and it held up pretty good. Never got off the spray while making shifts unless the car got loose.
Old Dec 4, 2003 | 09:00 AM
'94 Bad A Z28's Avatar
I have a built 4L60E, I spray through the shifts, no problems yet, car shift just as quick and hard as ever.
Old Dec 4, 2003 | 04:03 PM
rskrause's Avatar
Moderator
cef97ws6 said it well. I'd be cautious with a hi-po setup spraying through the shifts on a stock tranny though.
Rich Krause
Old Dec 4, 2003 | 04:08 PM
I am about mid to low 12's on motor only. I havent able to get to the track since a few mods. I have a built 700R4. Looks like I will find out in spring if it will handle it
Old Dec 5, 2003 | 09:32 AM
Derrick Redd's Avatar
My built 4L60E hasn't had a problem yet running 11.0's. I spray out the hole and through the shifts. If I ever get the tires to hook on a nitrous launch, I should see 10.80's with the traps I'm running.
Old Dec 5, 2003 | 04:58 PM
Are you pulling 1.61 60fts on the stock rear?
Old Dec 5, 2003 | 06:55 PM
SDAKOVIC's Avatar
I run a 175 shot and always spray thru all the shifts.
Old Dec 6, 2003 | 11:05 AM
Yes, I've pulled a best of a 1.55 60ft. on the stock 10-bolt.
marlar98
Sep 19, 2015 07:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
CARiD
Sep 7, 2015 08:21 AM
War Engine
Aug 21, 2015 05:28 AM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
