spare tire well installation
I used those angled peices of metal with the holes for nuts in them that are used for garage door bracing. If you have a vice you can bend it to have a flat bottom and top to put the mounting brackets on and to use to mount on the bottom of the well. I also had a brace running upwards to the little mounting peice that sticks out from the side of the car to prevent it from moving side to side. I made one pair of roughly 6 inch long brackets for the front, roughly 3 inches for the rear. I also have 2 rubber nubs on the back of the car where the bottle sits up against. It is really secure and isn't moving anywhere! The best part I found about this was that the metal can be angled for not so flat bottom of the wheel well. I then used washers in the uneven places to make it level. If you have any other ?'s let me know.
squarehead
Nov 21, 2014 08:02 PM
Wolf Warrior
Sep 12, 2002 07:34 AM
ZPLYR 19
Aug 22, 2002 01:44 PM
i used to have a site but i can't find it, did u try searching for it yet?
