Is this Safe?
Old Oct 5, 2010 | 09:23 AM
Queens94z28's Avatar
Is this Safe?
Hi guys,
I recntly finished up my current build which consisted of a new oem 4 bolt main shortblock and AI H/C package. The cam is very mild but is great for the street. Rest of mods are in my sig. Do you think it would be safe to hit this motor with a 100 shot? I would would most likely go with the plate kit from Nitrous Outlet and all the necessary equipment to pull timing...etc.
What do you think?
Old Oct 5, 2010 | 11:27 PM
A stock LT1 can handle a 125-shot with no problems. You shouldn't have an issues with a 100-shot.
Old Oct 12, 2010 | 03:37 PM
rskrause's Avatar
Moderator
Sounds good to me, with a decent tune.
Rich
Old Oct 13, 2010 | 09:32 AM
Thanks. Do I need to pull timing for a 100 shot? If I get the car tuned for the nitrous, will that hurt my performance when not on the bottle?
I was thinking that I could use my current tune, which is somewhat conservative and just use an aftermarket igintion to pull a couple of degrees when I arm the nitrous.
Do you think that is a good way to do it? Based on all the reading and searches I have done, that might be an option.
Also, what is a safe rpm to spray? I dont want to be too hard on the motor.
Thanks for your advice.
Old Oct 17, 2010 | 08:41 AM
rskrause's Avatar
Moderator
I wouldn't spray below 3,000rpm. Yes, I would pull some timing with the nitrous. 2-4 degrees.
Rich
rideordie
Sep 7, 2015 08:22 AM
4586
Aug 24, 2015 11:04 PM
Aug 7, 2015 08:52 AM
Jul 10, 2015 02:23 PM
Jan 23, 2015 01:13 PM
