retard timing with knock sensor resisitor?
Old Oct 4, 2008 | 12:53 AM
pyro719's Avatar
Ok So I know you can disable the knock sensor in my car with a 3.9k resistor, wich I plan on doing. Well can I put another resistor on a switch so it will pull like 6 degrees of timing when the nitrous is armed?
Old Oct 4, 2008 | 05:13 PM
No. The resistor is just put there to match the resistance of the knock sensor, so the PCM sees 2.5V on the circuit, and assumes the knock sensor is still there. The knock sensor's is a piezo microphone, and the output signal is a variable frequency representing the noise the microphone is picking up. That frequency is "riding" on the 2.5V circuit from the PCM. Changing the resistance doesn't provide a variable frequency.
Old Oct 4, 2008 | 10:58 PM
pyro719's Avatar
Oh ok. Guess I'll have to pull timing with a mallory 685.
Old Nov 19, 2008 | 08:16 PM
JDL_Z28's Avatar
Just out of curiosity, will the knock sensor be disabled if you just unplug it?
Old Nov 20, 2008 | 10:43 PM
It obviously won't work if its not plugged in. But that sets a code (DTC 43) for the missing sensor, and the PCM runs almost constant retard (up to 15 degrees), based on engine operating parameters.
HectorM52
Jul 30, 2017 11:46 AM
mikey4play
Mar 15, 2015 11:45 AM
Jul 4, 2005 05:00 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
