one more try and im taking it off !!!
Old May 14, 2003 | 08:25 PM
  #16
94z'sson's Avatar
we use .036 on a 6AL and it is fine
but you need to make sure that your fuel pressure is at 40-45 psi at idle with the vacuum line on and have it a 53-55 psi at idle with the vacuum line off
also do you have the fuel pump installed yet? cuz your stock one wont be able to handle the extra fuel needed if it has wear on it
Old May 14, 2003 | 09:03 PM
  #17
94droptopz's Avatar
no im still waiting on the fuel pump to get here. the stock one has about 105,000 miles on it so im really hoping thats the problem. when i checked the fuel pressure it had about 38 at idle and 43.5 at WOT. is that not about right? thanks for all the help guys
Rob
Old May 15, 2003 | 04:48 AM
  #18
Joe Brodman's Avatar
GP Moderator
Uhhh, stock fuel pressure w/ the vaccum line off is supposed to be 43.5psi.
Old May 15, 2003 | 06:06 AM
  #19
94droptopz's Avatar
what is it supposed to be with the vacume line on at idle? mine was about 38 or so at idle with all lines attached,is that about right? i never took a vacume line off. why would you do that?is there a point unless your gonna run the car with the line off? just wondering. thanks guys
Rob
Old May 15, 2003 | 11:36 AM
  #20
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
I run my plug gap at .035 with a digital 6 msd. Your fuel pressure seems fine at idle with the line on. when taking it off, should climb up to around 42/46 at idle.
Old May 15, 2003 | 11:53 AM
  #21
Hawk's Avatar
i'm running 0.038 tr6's with a accel 300+ digital, no probs here either............
Did u check the coil???
Old May 18, 2003 | 08:30 PM
  #22
94droptopz's Avatar
well im still waiting on racetronix to get me my pump here. damn its been 2 weeks now. o h well. i'll let yall know as soon as i do.
Old May 19, 2003 | 11:13 AM
  #23
JSK333's Avatar
FWIW, taking the line off at idle simply simulates WOT, so you can check your idle and WOT FP levels without moving the car. But of course it won't actually take engine demands on the pump at WOT into account...
Victor Lamb
Aug 26, 2017 02:52 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
andrewcapps82
Jun 2, 2015 10:57 PM
Darth Xed
Jul 1, 2002 03:22 PM
