Nitrous, Pump Gas, high CR?
Old Jul 7, 2005 | 01:07 PM
ChrisUlrich's Avatar
If i'm running 11.8:1 CR on 94 Octane... spraying would cause me to detonate no matter what I did? I mean, for it to actually work efficiently?
I heard that with the high high compression and the nitrous... all the extra heat from the nitrous would cause me to detonate like crazy... this true?
Old Jul 7, 2005 | 03:27 PM
HarrisSpeedWorks's Avatar
Re: Nitrous, Pump Gas, high CR?
As long as you run the right plug for the amount you are going to spray and pull some timing you should be fine. How much do you plan on spraying? We run Sunoco 94 in our 12.5:1 LS1 with a nice size shot. Good tune is the key.
Old Jul 7, 2005 | 07:46 PM
150-200 shot... I want the 200 shot... but if i'm unable, then the 150 shot.
I am going to run 94 octane, but this is going to be a daily driver. Is that bad? haha
Old Jul 7, 2005 | 08:01 PM
You should be fine with either on 94, just pull some timing. Play it bit safe since it's your daily driver.
Matt
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
bandit383lt4
Dec 21, 2014 09:12 PM
simple
Aug 11, 2002 11:56 AM
dmaastr
9
Jul 1, 2002 02:22 PM
