need help with NOS fuel pump install
Old Jan 1, 2003 | 08:07 PM
Kyle@CSS's Avatar
I got it all mounted. Adn I intalled the plastic clip on the adapter. But when I slide it into the fuel line it doestnt hold. I dont understand what holds the adapter in the line. The clip wont stay on the line. Im thinking they sent me the wrong peice. Please someone help.
Old Jan 1, 2003 | 09:25 PM
green85z's Avatar
Which pump do you have? Is it the NOS 15763 pump with barb fittings?????
Old Jan 2, 2003 | 06:35 AM
Kyle@CSS's Avatar
Its the newer style pump. And the instructions are for the older pump. I could not figure it out. I got the relays, lines, switches, noids, and the rest installed, but I can not figure outhow that clip holds it. I would think it should be designed like how the filter was with that lip. Any suggestions.
Old Jan 2, 2003 | 07:39 AM
green85z's Avatar
Once you have the hoses pushed up on the hose barbs on the pump, you use hose clamps on each end. The instructions i believe tell you to use two on each end, I think the kit comes with 5 0r 6 total. I probably have a copy if you need one.
Old Jan 2, 2003 | 09:07 AM
Kyle@CSS's Avatar
I clamed the plastic piece to the adapter. i clamped the lines together. it still leaked. I must be missing something. that plastic peice will not stay on the adapter
Old Jan 5, 2003 | 12:08 PM
SDAKOVIC's Avatar
I e-mailed you a PDF file on this. Let me know if it helps.
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
