nano system info
nano system info
Im looking to buy a nano system for my truck. It is a nice chunk of change and I trying to weight my options. My question is , has anyone ran a normal system and then added this to see how much of an et difference there is? I can definately see how it would help once the bottle is depleted some, just curious to how accurate there claims are of 25% more hp down track.
Remember... the nitrous bottle pressure starts to drop as soon as you start to use the nitrous, no matter how full the bottle is. When you remove liquid nitrous from the bottle, some of the remaining nitrous has to vaporize, to fill the space created. That vaporization removes heat from the liquid nitrous, cooling it down, and lowering the bottle pressure. Obviously the more full the bottle is, the less the pressure will drop. I think the NANO website shows a comparison of a system with and without the NANO system. Of course, it would be great to get some actual results, since the manufacturer might embellish things a bit.
You might want to check out this months GM High Tech Performance. They tested the NANO kit on a LS1 TA with a dry kit...on the 175 jets it pick up around 25hp and on 300 it picked up close to 50hp. They also saw similar improvemants in ET.
Noct
May 26, 2016 10:26 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
