which n20 system?
Old Feb 24, 2008 | 07:14 PM
  #16
Chopstix's Avatar
The Racetronix kit comes with a Walbro 255 pump and a dedicated wiring harness for the pump....this ensures consistent voltage at the pump.
255 alone will support ~5-550whp
Racetronix kit will support ~6-650whp
Old Feb 24, 2008 | 07:23 PM
  #17
Airbornec507's Avatar
Where are you getting those numbers from? Not arguing just interested to know.
Old Feb 25, 2008 | 09:16 AM
  #18
Ray@NitroDaves's Avatar
Data collected from customers and the countless cars we have helped tune.
There are cars that have seen more and a few that will run out of pump before then.
Old Apr 28, 2010 | 06:14 AM
  #19
Bersaglieri's Avatar
I didnt realize their kit could support that much...I already have their 255 pump, maybe I'll get the kit incase I run some juice...only think I wonder is if the fuel lines can handle the volume needed?
-Dustin-
Old Apr 29, 2010 | 11:46 AM
  #20
Stock fuel lines will be fine. I'm supporting 800HP (300-shot) with -6AN lines, same diameter as the stock supply line (3/8"). Rich Krause has run his 800rwHP blower setup on stock fuel lines.
Old Apr 29, 2010 | 09:18 PM
  #21
Thanks Fred, I was wondering how the stock lines related to -6AN line. You run dual nozzles in that or what?
-Dustin-
Old Apr 29, 2010 | 11:30 PM
  #22
I have a one-of-a-kind 300HP dry shot. Two NOS fan-jet nozzles in the outlet of a WS6 airbox, no MAF - engine runs speed-density on a MoTeC M48Pro ECU, which is capable of supplying the fuel through 78#/HR injectors running at 58psi. Extremely simple system.
Old Apr 29, 2010 | 11:40 PM
  #23
I was thinking about going to speed density tuning and losing the MAF, but I've got a lot of reading to do in the tuning section.
-Dustin-
malikot02SS
Aug 15, 2015 01:11 PM
350350
14
Aug 11, 2015 12:03 PM
MikeWhitener
Aug 2, 2015 06:17 PM
RUNMYTA
Jul 15, 2015 07:50 PM
