LT1 Install Pics
Old May 12, 2007 | 10:21 PM
  #16
CamaroRacing12's Avatar
kool setup man...nitrous always has interst me but im gonna wait on it...u should put the flip cover of the ashtray back on to hise the switch panel.... i think that be cool
Old May 13, 2007 | 10:02 AM
  #17
Sinister95Z's Avatar
Originally Posted by 2000GTP
Where do you have your solenoid brackets fixed too? Are they welded to the strut tower brace?
Yes. I had two tabs welded to the strut tower brace and then bent some stock noid mounts into a "L" shape. In the future sometime, I may mount them directly to the STB.
Old May 13, 2007 | 10:04 AM
  #18
Originally Posted by red_warrior_z28
set up looks great, where did you get the blue radiator hoses from. is it a whole kit.
2000GTP is correct. I got the Goodyear hose kit from Summit Racing. It even came with the proper hose for the Oil cooler delete.
Old May 13, 2007 | 10:17 AM
  #19
I do plan on having the ash tray cover on to hide the switches. I have to buy one that is not broken in order for that to happen though...
Old May 13, 2007 | 01:34 PM
  #20
2000GTP's Avatar
I had to buy a non-broken lid also.
Old May 13, 2007 | 09:53 PM
  #21
Loadre's Avatar
An easy fix for the broken lids is drill a small hole at the pivot point on each side (where it usually breaks) then zip tie it lightly to the console. Did this to mine, and while it's not exactly like stock, it still pivots up and down.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jun 23, 2016 08:42 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
