LT1 Install Pics
LT1 Install Pics
After all my noob questions...Here they are. For those who don't know, I purchased one of Harris Speed Works Brute Force Wet Nitrous Kits and all the supporting and safety mods. I custom ordered all the hoses black with black AN fittings including SS black lines for the dual purge. I have the heated bottle mounted on the transmission tunnel and the line runs under the car along side of the fuel lines so that it exits under the hood in the stock location. I do not like the way most people mount the nitrous noids on top of the Intake, so I came up with my own solution as seen here. The noids are nice and beefy and the fuel noid has a FPSS attached with the line running back to the schrader valve. The nozzle is drilled and tapped into a modified Trick Flow elbow with 100Hp jetting. The WOT switch is mounted on the bottom bolt of the Holley throttle body via a Jimmy Jams bracket. For some more safety I also installed NGK TR6 spark plugs and a Mallory 685 Ignition Box to take care of more spark, Window switch and a timing retard.
The only things I have to finish is the dual purge routing, mounting the nitrous filter and wiring for the bottle heater. The heater is on hold due to a battery relocation in the near future. Those things are going to have and wait until my next set of days off. Don't mind my interior...it is all ripped out for some more mods that are on the way. Anywho...enough talking. Let me know what you guys think.
Nothing too special in that department yet. Just to make it functional, I went with a Jimmy Jams switch panel mounted in the ash tray opening. One day hopefully soon, I will have a custom made switch panel.
Very nice, I used the Jimmy Jams switch panel as well. This was before Nitro Dave released his version.
