just got the basic nx efi kit what else do I need?
I have a 94z28. Mods in the sig and a walbro fuel pump. What else do I need to make this work on an automatic car? Will a 15lbs bottle fit in the spare tire well? What all do I need as far as gauges and such. I plan on getting the genx2 upgrade. Any help would greatly be appreciated.
i was paranoid with my setup, so i had just about every safety feature i could think of.
got my window switch from harlan engineering, sprayed in 2nd gear and had the switch setup for 3000-5700. Fuel pressure safety switch. Oil pressure safety switch. Used an MSD retard box and ran a 100 shot with 2* of timing pulled. Also used a DynoTune bottle warmer, worked very well, it was pressure adjustable.
purge is more flashy than anything, but good to have if you accidentally leave the bottle closed and heater on!!!
a blow down tube is also a good investment, incase of said bottle closed, heater on situation, and it causes the 3000psi disc to blow it wont fill the car with N2O, itll dump it out of the car.
And yes, a 15lb bottle will fit in the trunk space, not sure of the tire well, i actually had mine in the front seat with me covered in a duffel back...but i like sleeper stuff like that.
IgorT.455/406
Mar 12, 2015 03:39 AM
