if i dont have a window switch
Old Mar 7, 2003 | 03:49 PM
glennxx1's Avatar
is that when the engine takes a beating? i dont no too much about the whole fuel pressure thing, do u HAVE to have the pedal to the floor to spray? or is it RPMs that matter
, does a window switch stop the nitrous when u engage clutch or shift or w/e?
Old Mar 7, 2003 | 04:27 PM
LPEdave's Avatar
A window switch is a safety device that can be used to turn on and off your nitrous when you're outside an RPM "window" like 3000-6000. In theory, if you always shifted at the right time, and the engine never bogged, you wouldn't need or use a window switch. But stuff goes wrong, and the switch may save your motor.
You don't HAVE to have the car at full throttle, but it wouldn't make much sense not to. You're pumping in extra power with nitrous, there'd be little reason to use it if you didn't want everything out of the motor as well. But yes, RPM is the key, you typically only want to spray within a certain RPM range.
No, a window switch doesn't know if you're engaging the clutch or shifting.
You may want to read my "new to nitrous" guide in the sig for more info.
Dave
Old Mar 7, 2003 | 04:44 PM
glennxx1's Avatar
so i need to have somethin that'l stop spraying when i shift? or can the trany handle it
Old Mar 7, 2003 | 04:52 PM
glennxx1's Avatar
ouchers read the new to nos thing in ur info...100 shot on my stock lt1 ...goin to burn out my clutch and kill my rear? rut ro...deeef cant afford a rear end
Old Mar 7, 2003 | 06:56 PM
4DRSS's Avatar
Thumbs up
Great writeup Dave, thanks for sharing.
Old Mar 7, 2003 | 10:17 PM
glennxx1's Avatar
is Compucar plate system any good?
**nitrous kit
Old Mar 8, 2003 | 12:25 PM
stik6shift98's Avatar
Really helpful! thanks
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
z28cam1993
Sep 9, 2015 04:08 AM
