I had a problem..
Old Jan 23, 2006 | 11:35 AM
Grims's Avatar
I had a problem..
On the dyno when I sprayed nitrous, the car bogged way down then flames burst from the throttle body.
More info here: http://64.65.63.61/forums/showthread.php?t=424796
I noticed that when purging it didn't seem to be consentient...like a lot of air was in the lines. It would purge fine for a second then there would be a gap....could that of caused it?
I don't have any saftey equipment to speak of and am very lucky that all it did was screw up my MAF.
Any ideas on why it decided to blow up on me? I have been sparaying with this tune for a long time with out problems.
Old Jan 23, 2006 | 01:13 PM
jsetzer's Avatar
Re: I had a problem..
Could have been so many things. Are you running a n20 filter? How old are the solenoids. Is this a dry/wet setup? What was bottle pressure? If your purge doesn't look right it may not be feeding from bottle or lines right.
What jets?
I have heard of shops being really cheap and pumping their n20 tanks dry when filling peoples bottles. They do this to make as much money as possible, but end up pumping air into your tank.
Could have just been a backfire, It does happen. Lucky you didn't hurt anything.
Old Jan 23, 2006 | 01:37 PM
Grims's Avatar
No N20 filter, not sure on jet size..it has been so long. But it is a 150 shot. Solenoids are a few years old. it is a wet setup. bottle pressure was real low, 600psi (I didn't know this before spraying.)
I had the bottle filled at the drag astrip.
Old Jan 23, 2006 | 01:42 PM
jsetzer's Avatar
I don't "KNOW" but have heard that low bottle preasure makes early activation a bigger problem...
How low in the rpm band were you spraying? I would say put it up to 1000 psi and hit it again....
Old Jan 24, 2006 | 09:26 PM
Nitro Dave's Avatar
Sounds like your bottle was either really cold or you were out of nitrous. However there are many factors that could have caused what happened. Get a window switch on there.
Dave
Old Jan 24, 2006 | 09:29 PM
Grims's Avatar
I started spraying at 4000 rpm.
Dave
Going to order one asap, already got the pressure regluated bottle heater.
What igniton do you guys think I should go with?
Countryboychevy
Jun 13, 2015 02:49 PM
ibringdarukus
Sep 13, 2006 12:08 PM
matt95camaro
V6 Tech
19
May 12, 2005 06:07 PM
Livid97Z
Oct 10, 2003 03:13 PM
lt1camaroman93
Mar 30, 2003 03:23 PM
