how much timing retard for 300 shot
Old Jul 31, 2003 | 04:39 PM
amean94ta's Avatar
id like to know
Old Jul 31, 2003 | 08:04 PM
amean94ta's Avatar
ttt
Old Jul 31, 2003 | 09:53 PM
11 sec gta's Avatar
If you have to ask, then you shouldn't be running that much nitrous.
Old Aug 1, 2003 | 06:51 AM
lt1camaroman93's Avatar
people have to ask questions to learn. Why get down on someone because they want to further their knowledge on something??? I personaly can't help you with the amount of timming you need to pull i just thought the last comment was rather rude.
Old Aug 1, 2003 | 11:15 AM
Nostang 96z's Avatar
A good rule of thumb is 2 degrees pulled out for every 50 hp in nitrous but it all depends on your tune, combo, etc.
Later
Matt
Old Aug 4, 2003 | 01:27 PM
snow2000SS's Avatar
Pull 3 per 100hp. 2 per 50hp is good for pump gas but not so good on race gas. And if you're not running race gas with that much nitrous then you are asking for trouble no matter how much timming you pull.
Old Aug 4, 2003 | 10:29 PM
spraytheway's Avatar
Are you using a fogger or plate?
I would take out at least 15 degrees for the first hit. I also would put the car on fuel the first time as well. Look for specalling on the ceramic of the plug. If there is remove more timing or down jet the system. Also make sure you set up the fuel 100%. You need a real good tune to make real power and keep the pistons in it. Talk to you local NOS guru. Good luck.
Old Aug 4, 2003 | 11:49 PM
amean94ta's Avatar
thanks guys. i think i will have kenndys dyno tune in niagra falls ny do it when they install lt1 edit. but this helped me understand nitrous better. how long if tuned right till next rebuild? i used to run alcohol and we tore it down every year needed to. so how long i hope to get atleast 100,000 street miles i dont have funds like i used to
mikey4play
Mar 15, 2015 11:45 AM
Noenav
Dec 6, 2014 07:35 PM
