How much timing retard with 13:1 and 110 oct.
I will be dyno tuning soon starting with a 150 shot. I was wondering what would be a good starting point with retard. I wasn't sure if the same general retard guidlines applied when running high compression and high octane.
Re: How much timing retard with 13:1 and 110 oct.
The way to use the dyno is to sneak up on it. Don't forget, timing will change the AF ratio. Start safe: rich without much timing. Maybe 22-24 degrees. See what effect small changes have. Listen carefully for detonation, don't be afraid to pull a plug or two(assuming you know the fine old art of plug reading).
Rich
Rich
