How to add a window switch?
Old Dec 23, 2006 | 12:53 AM
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
I am currently running the Crane HI-6 with the matching LX-92 coil. I am on the cusp of spending some cash for a 125 wet shot but havent been able to figure out the window switch part. If my ignition does not have it built in how do I add it?? Can I trust my own finger with a button on the steering wheel?? I have an A4 with the Transgo shift kit so I am currently planning on spraying through the shift. The stall is 2400 so I am pretty sure I can do it with a button and let go at the end of the track. Thanks.
David
Old Dec 23, 2006 | 04:56 AM
MichiganSkip's Avatar
What's the P/N of your Crane? I didn't think the Hi-6 had Window switch capability built into it..But you can buy a window switch and hook it into your set-up. I can get you a detailed schematic on how to do that if you like.
Old Dec 25, 2006 | 02:32 PM
OBE1 95Z28's Avatar
A RPM window switch is a simple device, it completes the circuit when your RPMs are within the window (i.e. starting rpm of 3,000, enfding rpm of 6,000). The RPM window switch can be connected in line with the throttle position sensor, so that the nitrous won't fire unless you're at both WOT and the RPM is within the window.
Old Dec 26, 2006 | 10:12 AM
dren70's Avatar
I understand what it is and how it works. I am asking how to add it on if my Crane ignition does not support it?? What do I put in line with the TPS?? It sounds like some kind of device that reads the voltage and then only completes the circuit (closes its contact) when the voltage is above a setpoint. That sounds good. Please send me some kind of part / manufacturer name or link if you have seen this.
Here is the link for the Crane HI-6 http://www.cranecams.com/index.php?s...&lvl=5&prt=130. I don't need the schematic yet but thanks for the offer. Where do I get just a seperate switch?? Where do they wire into the system to know what the rpm is?? I know my Hi-6 has an output for a tach so is it maybe here??
Thanks for the info. I am sure I will find what I need in y'alls knowledge base. Thats right, I said y'alls.
David
Old Dec 26, 2006 | 10:37 AM
dren70's Avatar
I just got off the phone with the Crane tech line and there is no support specifically for the window switch. It does do the timing retard so wiring that into the control is easy enough but the window switch will have to be totally seperate.
David
Old Dec 26, 2006 | 10:58 AM
dren70's Avatar
I found it. I started searching nitrous controllers and found all kinds of stuff. ZEX, NOS, etc... They all make them. The ZEX one even lets you skip first gear and wait untill second to start spraying. They take the 0-5 volt TPS voltage and rpm from the ignition to enable the 12 volt output. It's all built into one device for as little as 140 bucks. Thanks.
David
Old Dec 26, 2006 | 12:11 PM
David
Be careful how you wire those window switches. Most are only good for a few amps. IF you try to fire the nitrous solenoids right off the window switch contacts, you're likely to burn the window switch contacts up. Check the current limitation on the switch before you wire it in.
Old Dec 26, 2006 | 12:36 PM
OBE1 95Z28's Avatar
[QUOTE=dren70;4303549]I understand what it is and how it works. I am asking how to add it on if my Crane ignition does not support it?? What do I put in line with the TPS?? It sounds like some kind of device that reads the voltage and then only completes the circuit (closes its contact) when the voltage is above a setpoint. That sounds good. Please send me some kind of part / manufacturer name or link if you have seen this.
If you truely understand what it is and how it works, then the explanation I provided above, to wire it in-line with your TPS, is all you need. It is totally separate from your Crane ignition.
Old Dec 26, 2006 | 08:29 PM
OBE1 95Z28's Avatar
Here's a link to detailed wiring instructions for a Mallory Window Switch:
http://go.mrgasket.com/pdf/628.pdf
Old Dec 27, 2006 | 04:14 PM
dren70's Avatar
thanks for all the great info guys. i appreciate the help.
david
Old Jan 5, 2007 | 05:22 PM
dren70's Avatar
I see the Mallory in the link you sent but thats too much relay logic. One pair of wires for an on and another set of wires for an off, no thanks. The nitrous controllers have the one enable contact with multiple controller inputs.
It will definately be on its own dedicated circuit s_willlis. All I will use the controller output for is to throw the relay.
David
willismoons
May 27, 2015 04:03 PM
MichiganSkip
Aug 31, 2002 08:52 PM
Speeds8erM-1
Aug 20, 2002 09:12 PM
Redbird
Aug 2, 2002 06:50 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
