Fuel pump...
Old May 4, 2003 | 06:53 PM
craigffb's Avatar
Fuel pump...
I'm thinking about upgrade my fuel system. My car has over 100,000 on it and I'd just like to be safe and be able to run a 100 shot if I want. What you suggest, a new aftermarket in tank pump, or just put an in line in?
Old May 5, 2003 | 02:39 PM
craigffb's Avatar
OK this is nuts. I know someone on here had to have upgarded the fuel system to help run nitrous.
Old May 6, 2003 | 01:52 AM
RAMIN 94 TA's Avatar
An in-line shoud meet your needs, depending on what type of NOS you run.
Old May 6, 2003 | 02:47 AM
craigffb's Avatar
It's a NX wet kit. I wouldn't run any thing more than a 100 shot. I was also wandering if it would be chaper to go with the in-tank Walbro?
Old May 6, 2003 | 03:12 AM
Its about the same, I would go with whats easier which would be the in-line.
I hate the thought of removing the gas tank
Paul
Old May 6, 2003 | 03:16 AM
craigffb's Avatar
I do too. If I went with the in-take pump I would go the route of cutting the hole in the hatch area. Any suggestions on a brand of in-line?
Old May 6, 2003 | 03:55 AM
NOS makes a good booster pump, That s what I run.
You can get it from summit or you can go with a MSD
for about haft the price.
NOS-----$200.00 Summit supports up to 700 HP
MSD-----$100.00 Racenet supports up to 500 HP
Old May 6, 2003 | 03:59 AM
craigffb's Avatar
Thanks.
Old May 6, 2003 | 06:53 AM
Hawk's Avatar
a little 100 shot??? You don't need a fuel pump, don't waste your money. If u want safety buy a $40 FPSS and call it a day. STock fuel pump is good up to a 150 shot, after that it could get hairy(this is on a stock motor Lt1 BTW, if you have cams/heads diff story)
Old May 6, 2003 | 11:52 AM
craigffb's Avatar
I've got a FPSS and a fuel pressure gauge. So you thank a stock fuel system with over 100,000 can handel a 100 shot?
Old May 6, 2003 | 01:52 PM
IMO I would be safe than sorry, Its worth the money to up-grade your fuel system when you want to spray.
Paul
Old May 6, 2003 | 02:10 PM
94droptopz's Avatar
racetronix has a gp going on right now for a 255lph in-tank pump kit for 149.00 im fixing to buy one myself just to be safe pluse im doing a lot more to my car soon anyways.
Old May 6, 2003 | 02:28 PM
craigffb's Avatar
I've found the Walbros on ebay new for right around $100. You
should take a look. I just don't know if I want to do in-line or in-tank.
Old May 6, 2003 | 02:59 PM
94droptopz's Avatar
if you'll look in the GP section you'll see the racetronix kit comes with all the hardware to install it properly in your camaro as where the one on e-bay is just the pump which will not fit into your orginal fuel bowl.
Old May 7, 2003 | 08:11 PM
RUFFIDLNZ's Avatar
I ran the stock pump with a T-Rex inline pump and was shooting a 200 shot with no problems. I kept the O2s up in the 900 range just to be safe so basically I was running rather rich.
Just a note you can get the Holley to fit in the stock bowl you just have to work at it a bit and use a fine bit of sticky stuff to assure that the top doesnt come off. We did this on a buddy of mine's 93 Z and its still running fine with no problems at all. Just my .02 but if I was you I would go with the inline cause it is much easier to install and will be more than enough for you.
Glenn
