Do you need a window switch for a lt1 fbody?
It was probably putting to much strain on the trans trying to pull the hp. I dont think its a good idea to spray through the shifts anyway which is why i have the window switch shut the spray down right before it hits the next gear.
If it is a weekend warrior/race car you want to spray through the shift. I have my on point set to 3K and off at 6.8k. Rev limiter is 7k and launch RPM is 4K+ with convertor flash. My kit is spraying before the car moves and doesn't shut off until I let off the gas. This is with a 700r4 tranny with just a few internal mods
sorry...maybe I should have pointed out, how I have gone through the transmissions.
Stock the car had a T56. This was on a H/C/150shot combo ran 12.0 @ 120+ (2.0 60') But did break a Spec stg3 clutch in half on a 1-2 powershift.
This combo had a road race suspension setup and was useless at the strip.
I converted to a drag suspension and a 700r4 auto with a 2800 stall. Also was running a 396cid making 422/447 NA and 566/604 on a 150 shot. (HP #'s are from the T56) First tranny died in 2 weeks due to converter failure.....rebuilt the tranny and 2 weeks later the converter failed again. Turns out the flex plate was bent
New tranny has everything that can be done to the 700 and a billet 32-3500 stall. Have had no issues out of this one in 2 years. But we will see how it likes 700+whp
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
