nitrous plugs
Old Jun 5, 2008 | 02:35 PM
White Lightning's Avatar
nitrous plugs
anyone ever use these NGK BR7EF? in the sticky above it says it s 2 steps colder than stock,. just wondering if any gains to be had
Old Jun 6, 2008 | 09:04 AM
shiznityz28's Avatar
There are no gains in a colder than needed plug. but if thats the correct heat range and you have been using a hotter plug than there are gains. what shot?
We use 7's on 150-200 shot
8's on 200 -250
9's 250-300
10's 300+
But we have found ET heads like 1 step colder and stock and AFR like the above. this all considering a well built health hp motor(450+). less motor hp and it may move down a step.
But you need to look at your plugs to see if there the right heat range.
put a brand new one in make a hit cut the car off going threw the traps pull it out cut the treads off so you can see the fuel ring and read a few plug reading articles. it will help( even on small shots)
Old Jun 6, 2008 | 06:49 PM
im running a 175 shot and will be going to a 250 or 275, i had tr6's in it and just figured i would change these and see what happens
Old Jun 10, 2008 | 05:08 AM
1982z28with18s's Avatar
I run those on my turbo setup, so far driving on them has showed that they don't foul out nearly as bad as I thought they would, haven't fouled one yet.
Old Jun 10, 2008 | 11:38 AM
drperformance's Avatar
I am sorry to jump in but I am running a 383 LT1 with 12.8:1 compression and a direct port 200 shot. My TR6's turned slightly green so I am now putting in NGK BR7EF, what do you guys start your gap at? I believe they come at 25. I have a mallory hyfire cd ignition, mallory promaster coil and a msd opti.
thanks
Old Jun 10, 2008 | 11:53 AM
Ray@NitroDaves's Avatar
here is a link to reading plugs....
http://members.uia.net/pkelley2/sparkplugreading.html
this will show you what to look for on heat range
camaroguy50613
May 27, 2016 09:00 AM
RUENUF
Mar 13, 2016 03:39 PM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
bandit383lt4
Dec 21, 2014 09:12 PM
